查看: 125|回复: 6
[多场耦合] 【请教】使用rigid link施加角速度时的问题
发表于 2011-8-24 16:34:38 | 显示全部楼层 |阅读模式 来自 江苏南京
我想对结构施加旋转运动。
按照版里提供的方法,先对体上某一点施加旋转运动,如下图所示
然后使用rigid link命令,
运行产生如下提示,请问这是什么情况?(PS:我把自由度限制为仅绕Z轴转动)
ADINA data input file E:\ADINA\thrust0823\thrust_s.dat successfully updated.
***WARNING: Rigidlink 1 has no nodes on master point 37.
             The automatic time-stepping method will not be used in linear analysis.
             No element connection for node 1 direction 6
             No element connection for node 2 direction 6
             No element connection for node 3 direction 6
             No element connection for node 4 direction 6
             No element connection for node 5 direction 6
             No element connection for node 6 direction 6
             No element connection for node 7 direction 6
             No element connection for node 8 direction 6
             No element connection for node 9 direction 6
             No element connection for node 10 direction 6
             No element connection for node 11 direction 6
             No element connection for node 12 direction 6
             No element connection for node 13 direction 6
             No element connection for node 14 direction 6
             No element connection for node 15 direction 6
             No element connection for node 16 direction 6
             No element connection for node 17 direction 6
             No element connection for node 18 direction 6
             No element connection for node 19 direction 6
             No element connection for node 20 direction 6
             No element connection for node 21 direction 6
             No element connection for node 22 direction 6
             No element connection for node 23 direction 6
             No element connection for node 24 direction 6
             No element connection for node 25 direction 6
             No element connection for node 26 direction 6
             No element connection for node 27 direction 6
             No element connection for node 28 direction 6
             No element connection for node 29 direction 6
             No element connection for node 30 direction 6
             No element connection for node 31 direction 6
             No element connection for node 32 direction 6
             No element connection for node 33 direction 6
             No element connection for node 34 direction 6
             Message limit reached - above message has been suppressed 1391 times.
             Nodal degrees of freedom without element
             connection have been fixed for data input file.
             There may still be degrees of freedom without
             stiffness - see documentation.
             No displacement loads generated at point 37
             resulting from load application 1.
 楼主| 发表于 2011-8-24 17:15:51 | 显示全部楼层 来自 江苏南京
重新在某个face上建了一个点,上面的问题已经解决。
个人认为,该point必须存在于face/surface上,才能使用rigid link。请高手指教。
一个问题解决了,又出现新的问题……菜鸟伤不起啊。
继续研究!!!
发表于 2011-8-24 21:49:52 | 显示全部楼层 来自 北京
主点可以是离散的点,但是划分网格时不要忘了给主点划分网格。
 楼主| 发表于 2011-8-25 15:50:41 | 显示全部楼层 来自 江苏南京
回复 3# wild_field
哦?是因为没有给主点划分网格?怎么给点划分网格啊?
 楼主| 发表于 2011-8-25 16:17:24 | 显示全部楼层 来自 江苏南京
回复 3# wild_field
请教一下斑竹,“Prescribed displacement unloading option cannot be used in linear analysis”这个错误怎么处理(设置与上面一样)。谢谢啦~
发表于 2011-9-8 15:58:53 | 显示全部楼层 来自 浙江杭州
要对施加运动的主点划分点网格单元问题就能解决了!
 楼主| 发表于 2011-9-9 10:08:38 | 显示全部楼层 来自 江苏南京
我试试,谢谢!
GMT+8, 2024-11-1 23:39 , Processed in 0.037199 second(s), 11 queries , Gzip On, MemCache On.
